I'm using this guide:
http://www.digital-digest.com/articles/FLV_to_AVI_Conversion_Guide_page1.html
I had to skip the part about not interleaving the a/v because then it wouldn't play in my DivX DVD player.
Also I had to go VirtualDubMod's Video -> Frame Radio -> Option to have A/V Synced under Source Adjustment
Now this made perfect Xvid AVI's from about 12-15 FLVs but there are just 3 that will just not get A/V synced in this manor.
All 3 seem to have the sound before the video.
The original videos match up in FLV player.
Results 1 to 14 of 14
Well...
Upload some problematic FLV clip on kotuha.com.
Or if it's downloaded, show link to source. -
I found out the file is VFR and that it's FLV4.
Does this make a lot of difference or no? -
Is there any software that will defiantly read the timestamp file that FLV Extract outputs?
I figure if something will read that, then maybe it will be gold and no more A/V sync.
EDIT: Here is a piece of my FLV file finally:
http://kotuha.com/file/i3rES-t---S01E03---All-That-Glitters_part002_part002.html
EDIT: I just converted just that chuck like I normally do, and it's weird, that peace has no A/V sync error. Why would the whole thing have one then? -
VirtualDub 1.8.1 + DirectShow input plugin 0.5
Open video file... - choose file and change file type to DirectShow input driver.
When i'm try result is good (A/V sync).
(Required FLV Splitter and ffdshow (with active VP6F support).)
Avisynth script > VirtualDub
Example script:
When i'm try result is good (A/V sync).Code:DirectShowSource("d:\path\t---S01E03---All-That-Glitters_part002_part002.flv",fps=25,convertfps=true)
FFmpeg / MEncoder (and of course some GUI's) - can't determine FPS in this file.
Useless for this sample file.
VirtualDub 1.8.1 + FLV input plugin 1.1.0
Unfortunately - 'out of sync' A/V.
(Even with Change so video and audio durations match and Convert to fps.) -
Thank you, Thank you! Except for strange sounding audio.
Now the audio makes weird stuff like, noises, echos, etc. -
I tried to even play on another machine, but the audio still seems scratchy and it makes funny noises like someone going errrrrrrrr. It happens about every 60 seconds or so.
You hear the same sounds playing the FLV in Windows Media Player, but not in FLV Player.
I installed FLV Splitter and FFDShow. The audio is mp3. I tried both libmad and mp3lib.
It sounds like a drill or a zzzzzzzz sound every now and then.
Can you JOIN two FLVs?
By r2997790 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 04:04 -
FLVs and 15fps?
By CursedLemon in forum Video ConversionReplies: 4Last Post: 10th Oct 2009, 18:30 -
Problems with my FLVs!!!
By durgamata57 in forum Video ConversionReplies: 2Last Post: 8th Oct 2008, 11:17 -
Formula for encoding flvs
By stembridge in forum ffmpegX general discussionReplies: 5Last Post: 12th Sep 2008, 19:23 -
FLVs not looking too good...
By stembridge in forum ffmpegX general discussionReplies: 4Last Post: 26th Aug 2007, 11:40
