I need alittle help in adobe premiere video saving... i am editting Dv video captured via firewire in adobe premiere, my question is that when i save my movie in full quality that is AVI format, and after some time again i open the same AVI saved file to premiere and edit it and save it in Avi format , if i repeat the same step two times more, will the video remain in the same quality or it will loose its quality....?![]()
If you don't apply filters then there should be no change to the quality. If you do apply filters, or overlay text etc then those frames will be re-encoded, and this could eventually degrade the image visibly. Sometimes it may be visible after only a couple of re-encodes, sometimes it may take 5 or 6.
The secret is to save the project, which has all your edits in it, and if you have to make changes after encoding the video, make them to your original project, not the new footage.Read my blog here.
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
Saving view
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 14:18 -
Problems with Movie maker saving to dv-avi
By jbitakis in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 09:19 -
Not Saving the File anywhere
By MrBoiler in forum ffmpegX general discussionReplies: 8Last Post: 31st Jan 2010, 07:17 -
Do Movie Maker or Virtualdub re-encode DV-AVI when saving? Quality concern?
By sdineen in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2009, 21:47
