It was supposed to play Divx but says "non supported video format". Is this because of applying region hacks? Is there anything I can do to play divx on this?
Baldrick is of course right. We need more information.
Any of the following Divx encoding options might cause DVD players to have problems.
1) Use of QPel (Quarter Pixel).
2) Use of GMC (Global Motion Compensation).
3) Resolutions greater than 720x576.
4) Files larger than 2 GB in size.
5) Video bit rates higher than 2000 Kbps.
6) If you use AC3, LPCM or DTS audio, the video bit rate may have to be a lot lower than 2000, perhaps as low as 1200 for successful playback.
7) Packed bit stream (MPEG4Modifier can remove this).
All of these problems except #7 require re-encoding the video to remove them. My best guess is that your resolution is greater than 720x576. Almost no DVD players support HD Divx. Region codes are not the cause of your problem. -
I've tried with several avi divix, both on cd and dvd. I'm not very good with all these, but here is what gspot tells me:
Size: 699 MB (716,464 KB / 733,659,136 bytes)
Container
File Length Correct
DivX Style "packed bitstream" AVI
OpenDML (AVI v2.0)
Interleave: 1 vid frame (40 ms), preload=504
Audio frames: Aligned on interleaves
Video: 623 MB (89.17%)
Audio: 66.7 MB (9.54%)
AVI Overhead: 9.05 MB (1.29%)
User Data/Meta data
[ISFT] VirtualDubMod 1.5.10.2 (build 2540/release)
[JUNK] VirtualDubMod build 2540/release
[USER] DivX503b1393p
[USER] XviD0046
Video
Codec 0x0055 MPEG-1 Layer 3
Info 48000Hz 94 kb/s tot , Joint Stereo LAME3.97b
Cdec XVID Name XviD 1.1.2 Final
MPG4 NVOP PVOP BVOP PB - these are highlighted, (AVID, QPEL, GMS - these are not highlighted)
Len 1:38:52, Frms 148,298, kbps 882 Qf 0,153
Pics/s 25.000 Frames/s 25.000
pics (wx 656 x 352
sar 1,864 (41:22)
par 1.000 (1:1)
dar 1,864 (41:22)
Seems than problems 1-5 & 7 are not mine, no idea about #6... -
I've tried MPEG4 modifier (saved the file marking "unpack" in "packed bitstream" field), but still '"non supported video format". Any other ideas?
DVD shows me 750 gigs????
By lj5 in forum DVD RippingReplies: 10Last Post: 5th Feb 2010, 04:02 -
subtitle problem with DSM-750
By roise_r in forum SubtitleReplies: 1Last Post: 2nd Sep 2009, 03:44 -
Problem with LG LRA-750
By polus in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Mar 2009, 17:46 -
Hack for LG LD 750???
By sunnjack in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2009, 14:51 -
LG LRA-750 OP code request please?
By klingklang in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th May 2008, 20:55
