I ordered a computer that has a 100gb PVR and a DVD-R/RW burner with external front and rear audio/video inputs. Is it true that you cannot record directly to the internal DVD recorder, but must first record onto the PVR and then transfer onto the DVR recorder?
Thanks,
RDave
You have to capture/record first and then author and burn the dvdr. Buy a standalone dvd recorder if you want to record and burn directly to dvdrs.
Well if you wanna get MyDVD 3.0 from Sonic they have a direct to DVD-R feature. Not sure how well it works because i use DVDit! PE and it doesn't have the direct to DVD feature in the latest upgrade. According to the www.sonic.com web site it says you can go right from any analog or digital source directly to DVD without any extra steps, as easy as hitting record on a VCR. I think it's gonna be extreamly limited on bitrate settings and quality. I also believe you can get a program from MedioStream that does a direct to DVD-R program at http://www.mediostream.com/
Hope this helps. But if you really want good results, capture, encode, and author in seperate steps.
BarneyOk Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look! -
Thanks for the responses guys. I have the new Sony PCV-RX690G on order, and it comes with an integral PVR, DVD-R/RW and DVDit. I will probably use the capture/author/burn method to get the best results as you described.
RDave
Internal vs. External ripping
By hardy in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2009, 12:32 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 18:33 -
External/Internal dVD-R dual layer burner
By SIRCOOKS in forum ComputerReplies: 6Last Post: 14th May 2008, 12:45 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 18:12 -
Do internal/external DVD burners have copy protection built in?
By waldothewonderboy in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jul 2007, 00:01
