Is there a way to personalize or edit the menu templates in convertXtoDVD?
or is there another way or pgm that can do this?
thanks
If you mean to edit the included menu templates in the latest release of ConvertXtoDVD v3.xx, then no
I'm looking for something myself, the menus appear to be basically images with a huge .ini file to control what does what in the actual menu, but apart from that they didn't bother to actually make it very simple to create your own menu from scratch, but it is a vast improvement over the atrocious menus that were in the v2.xx of ConvertXtoDVD
You can edit the build-in menus upto a point but its not very user friendly and it certainly isn't easy to use in the sense of a drag and drop interface similiar to TMPGenc DVD Authors menu editor -
I don't use ConvertX, but you can replace what they give you after the fact by following my Menu Replacing guide. Since (I guess) these are just static menus, then scroll down to The Easy Way portion at the bottom of the post:
https://forum.videohelp.com/topic313743.html#1606732
You'll have to make sure that the new text lines up with the underlying subpics (make sure it's in the same place as before), or else you'll have to edit the subpics as well, and that's not nearly as easy.
Free After Effects Easy To Edit Templates[Openers,Elements,Displays...]
By aeffects.info in forum Newbie / General discussionsReplies: 1Last Post: 30th Apr 2012, 05:11 -
How create a custom Menu Backround when using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 15:49 -
animated menu w/ ConvertXtoDVD
By WhiteKenny in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2008, 16:13 -
convertxtodvd background menu fit.
By dymx in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2008, 21:52 -
Can not find any Menu Templates in EncoreDVD
By acid_burn in forum Authoring (DVD)Replies: 6Last Post: 8th Dec 2007, 17:18
