Can I load video from a DVC Pro-50 bit video tape into my mac? I have a HDV and a DV camera to play tapes from. Would the tape be compatible?
dvc tape is about four times bigger than miniDV/HDV. you will need dvc pro50 deck or cam to use them.
What software is on the Mac?
DVCPro50 is usually capped SDI (uncompressed). If this is a one time need, take it to a pro dub house and pay the $30-$40 dub to file fee (depends on length). They can dub to uncompressed, DV or other file format.
BTW: It isn't 50 bit. It's 50Mb/s and 8 bit components.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 16:06 -
XP Pro 32-bit v. Windows 7 64 bit
By edong in forum ComputerReplies: 13Last Post: 12th Aug 2010, 13:28 -
Premiere Pro - is it really 64-bit?
By bds in forum EditingReplies: 9Last Post: 5th Feb 2010, 16:18 -
Vegas Pro 8 on 64-bit OS
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jun 2008, 19:03
