I need to burn movie DVD from AVI file and need to add subtitle from .srt file. How can I convert .srt subtitle file in to DVD format![]()
Closed Thread
ConvertXtoDVD or the freeware Avi2Dvd can do that if you want an easy way. Probably others in: https://www.videohelp.com/tools/sections/all-in-one-dvd-converters
BTW, using a larger font won't help get more answers, you will probably get less.
And welcome to our forums.
If you are playing them back form a standalone this is important. For most authoring tools it isn't so much of a problem because you can select the sub files separately, regardless of what they are named.
Read my blog here.
I spent like 16 hours converting adding and burning and still ended up really bad sinq to the dialogue. But I found a great free video converter and burner that adds srts right next to your selected video ,, and it even can squish like 20 episodes of a tv series onto one 3,5 dvd. so what is this miracle,you ask? Its: FREEMAKE VIDEO CONVERTER
Johndee
I use ConvertXtodvd which takes avi and srt files and converts to dvd, but I put on at least 4 sets of subtitles because of syncing problems. Really user friendly program, although if you put say 3 movies on, the conversion is quite slow, up to 2 hours. If anyone else is using this program, is there a way with it to sync subtitles?
My favoutite subtitle sites:
findsubtitles.com subscene.com
Have a great day everyone and hello from Australia
Champannie
.srt Subtitle in "not DVD" File like mp4, mov or avi
By oldMac in forum ffmpegX general discussionReplies: 2Last Post: 8th Apr 2010, 19:12 -
Video quality worse after burning .srt subtitle into .avi file
By twenty in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 08:51 -
[Question] How to insert an SRT (Subtitle) file into an AVI file?
By Greg14 in forum SubtitleReplies: 5Last Post: 30th May 2009, 05:54 -
Avi file wont play when playing with .srt subtitle
By cudencuden in forum SubtitleReplies: 2Last Post: 25th Mar 2009, 21:40 -
Burn .VOB File with .SRT to DVD+R DL (HELP!)
By holdenmcclure in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 01:47
