    Jun 2008
    I really need some help.
    I am streaming using WME with previously encoded files which is working fine so far. Now, I want to capture a Gospel Channel via DAC100 and stream with WME but I am unable to insert logo with Live Alpha.
    Also, the Audio level is very low. Anyone knows how to solve this issue?
    Aug 2004
    I have a DAC-200 - if you're converting composite to DV - you need to have appropriate audio levels going into the DAC-100 as you're not going to be able to adjust audio via WM based on DV input. Your levels before hitting the DAC are too low if it's pumping out low out of WM Encoder.
    I use Convid Live Alpha and use PNG files and use Black as the transparency and it works like a charm. What specifically are you having problems with in that program?
