Results 1 to 9 of 9
  1. I'm not sure why this is happening...
    I have a project set-up in Adobe Premiere. It's PAL Widescreen 16:9 (1.422). I have an After Effects composition which I've also created, and it is also PAL Widscreen 16:9 (1.422). I am rendering a movie file from this After Effects composition, and then taking that file into my Premiere Project. But for some reason, when I export the movie from Premiere, it is not 16:9 format. It is squashed in left and right. I don't understand why. I have some still images in my Premiere project, and they are the correct ratio, so why isn't the movie file I rendered from After Effects!? Crazy thing is that the movie file from After Effects IS! I'm stumped!!
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Check the output clip file properties from AE and make sure it is flagged 16:9 wide. Actual 720x576 PAL (DV, DVD MPeg2, Uncompressed SDI, etc.) should look squeezed horizontally when viewed directly. The preview window responds to wide flags.
    http://www.kiva.org/about
  3. Well this is what has me a bit confused because the clip on it's own seems to be as it should. When i view it independently, it's the correct size (or atleast appears to be). It's only when I get it into Premiere and export from there that it doesn't behave properly. Yet the still images within the same project ARE ok...!
  4. OK, i seem to have found a solution, but i'm not sure it's the RIGHT thing to be doing.
    By changing the composition settings in After Effects to PAL Widescreen Square Pixel at a resolution of 1024x576, when I then take that file into Premiere and export the movie, everything is the right proportion.
    I feel like this isn't the right thing to do though...!
  5. Member edDV's Avatar
    Mar 2004
    If you export square pixel, Premiere will squeeze it again. Instead figure out how to set the "wide" properties flag. I don't have the AE program here. Trying from memory.
  6. The original clip I rendered from AE is wide, from what I can see. When I play it in VLC Player and select the 16:9 ratio, it looks correct. It's only when Premiere exports it that it squashes it up. But the square pixel thing seems to do the trick. Maybe it shouldn't, but it is working...
  7. Member edDV's Avatar
    Mar 2004
    What format are you outputting and how are you monitoring it?
    720x576 wide should look h squeezed if viewed in square pixel. A square pixel player set 16:9 will expand to 1024x576 for square pixel 16:9 viewing.
  8. Originally, I was outputting from Premiere at PAL Widescreen 16:9 (1.422). Watching square pixel, it looked squeezed double on the footage that I rendered in AE, although the stills photos looked squeezed as you would expect. Viewing 16:9 the photos expand out to normal proportion, but the AE footage was still squeezed.
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What compression and format are you using ? Not all of them respect the 16:9 flag, so while your video will be encoded correctly, you may have to tell your editor or playback software that it is 16:9. It appears this is happening in your case, as you have to tell VLC that it is 16:9. VLC is usually pretty good at working this out for itself if the format supports the flags properly.
    Read my blog here.
