Hi all
Just spent ages renaming all my avi files under vista.
Sent them to my PS3 and low and behold they still have their original file names. Tried them on media player on Vista and sure enough, their original filename.
Say I have a file called aaa.avi.
I right click on file, click rename and change aaa to xyz.
I now double click on xyz.avi and media player shows it's playing aaa.avi.
Hope that makes sense. I tried downloading the program abcavi but the tags section is showing the file as I renamed it.
Sure it's a simple one for you good folk.
Someone on AVforum gave me the answer.
Simply move the renamed files to another folder on Vista.
Sure enough, this worked -
Only on Vista would it somehow be necessary to move a file to another folder to make renaming work. At Microsoft, quality is job none.
Help Rename Title !
By bk_mutante in forum AudioReplies: 0Last Post: 19th Dec 2011, 22:52 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 20:49 -
To Remove Title in AVI-XviD videos
By shans in forum EditingReplies: 6Last Post: 28th Mar 2011, 21:21 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 21:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 10:32
