what should be the format for burning files onto DVD so that I can watch them in DVD players.
I have some.DAT files that I need to burn.. And please suggest me some software using which conversions can be done easily and using which I can convert multiple file formats......
Extract the content of the dat files back to mpg using VCDGear, then use tmpgenc DVD author to author them to DVD. It will upsample the audio to 48kHz for DVD compliance, and leave the video as it.
Read my blog here.
dat files are probably from vcds and I would then try tmpgenc dvd author as it wont reconvert them if they are dvd compliant. If tmpgenc dvd author wont open the dat directly try vcdgear them to mpg first.
If you want free tools then try vcdgear the dat to mpg and then use all-in-one converters like dvd flick to convert the mpg to dvd.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
