I have a Dell OptiPlex GX270 with a dead mobo (this model had a manufacture capacitor issue) and I need to know the FSB speed of my processor so that I may order the correct one. The motherboards I'm looking at are compatible with 400/533mhz; 800mhz is not compatible. Did this model come with a 800mhz option?
Results 1 to 12 of 12
http://www.dell.com/downloads/us/products/optix/gx270_spec.pdf
That motherboard supports 800, 533 and 400 MHz FSB. I'm pretty sure a 3.4 GHz P4 (listed in your specs) will have an 800 MHz FSB.
Be careful buying motherboards for Dell cases. I don't know that particular model but some have unusual mounting holes and dimensions and different power connectors. -
Thanks for your reply. I'm trying to find out how to determine which FSB option that I have. The replacement mobo's that I'm looking at are not compatible with 800mhz processors.
You could use a tool such as SIW and get more information than you ever wanted to know.
http://www.gtopala.com/Google is your Friend -
Or CPU-Z: http://www.cpuid.com/cpuz.php
But with a dead motherboard he won't be able to run any software. -
Look for the s-spec number on top of the actual processor. It is a 5-digit alphanumeric starting with S. Then go to Intel's website and find the processor model using that number.
FB-DIMM are the real cause of global warming -
Why exactly is it that you wish to spend money on out-of-date, obsolete equipment?
If you can wait a bit, I'll likely be throwing a 400 MHZ board into the garbage, probably some CPU chips, as well,
I don't think they made a 3.4 at 400, you probably have an 800 MHZ chip. If not, get a new chip to go with the new board. -
Originally Posted by Nelson37
Originally Posted by Nelson37 -
you would be better off going to a place that has computer auctions (not a website)
you should be able to pick up a complete PC (without monitor), more up to date model for less than the cost of a replacement motherboard. -
Originally Posted by Eyecan'tcode
You could look at the service tag number on the case and go to Dell's part website and find out exactly what you need.
Oh, one more thing, unless it a Dell replacement board, the MoBo you buy may not fit in the Dell case. If you notice the position of the CPU on the Dell board (the heat sink and the fan which blowing air toward the CPU under the big green plastic cover), you may have an BTX case and ATX mother board will not fit in the case without major modification to the case. -
It was more cost-effective to upgrade the system, rather than replace everything.Want my help? Ask here! (not via PM!)
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
has anyone find out what the problem is?
By suav3sito in forum SubtitleReplies: 0Last Post: 12th Aug 2008, 14:28 -
Where to find SUBSYNCH
By Wan Dat Ting in forum MacReplies: 3Last Post: 18th Jul 2008, 19:15 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 21:25
