    Apr 2006
    I have some questions about Quenc settings, as I am trying to make a front-end batch application for it. Some of the questions may just be basic video encoding questions. I have looked at the Quenc_settings.txt that comes with it and my questions are based off of it.
    1) As far as video encoding, I believe that you cannot encode a video with Bottom Field and Top Field set at the same time. The question is, does it have to be one or the other?
    2) I am trying to figure out how to handle the Mux Profile argument. Currently you have 3 types (mpeg2,mpeg1,mpeg4) and those breakdown further to give you more options (noaudio, separate etc etc). Since it seems that you cannot specify a video codec (output), it seems like the Quenc Gui itself determines which Mux options you will have based on the AVS file. Would the program be too limited if I only provided 1-3 options (noaudio, novideo, separate)? I know the mpeg4mux doesn't have the separate option, but I am not sure how this portion works.
    Edit: My question about the pulldown still stands, is there a way to figure out what is being passed?
    Edit: I am also thinking about adding an existing application I wrote a while back that uses DGPulldown. Basically, it allows you to make a batch file of the MPEG-2 files you just rendered or the program itself will run DGPulldown for you (therefore you have more control) and you can make better use of multithreading. Of course, there would be no need if I can get the pulldown the Gui uses.
  2. Banned
    Freedonia
    Read up on what interlacing means (we have a Glossary section here under "WHAT IS") and you'll have a better understanding. Yes, it has to be one or the other with interlaced video. There's no such thing as Bottom Field or Top Field with progressive video.
    I have never used Quenc and thus cannot answer your other questions.
    Dec 2004
    Triptonia
    why?
    I've already answered.
    it's not being passed.
    quenc determines nothing
    it's not really cli either.
    so you have to activate, and disactivate each and every setting
    you specify codec by specifying muxing profile. backwards but hey.
    well,
    one should not really use it for mp4. i can;t see why at least.
    and if you can;t do pulldown, and you're mostly dealing with progressive 23.976
    the above will cover you.
    but it is limiting in other scenarios yes
    tripp
    "I'll give you five dollars if you let me throw a rock at you"
    Apr 2006
    @45Tripp, thanks for the feedback.
    I looked at KuuEss's Batch Encoder for Quenc and they have a Pulldown checkbox, so I just wanted to put it to the forum again.
    I downloaded the source code for Quenc, but it is too combersome and I haven't seen C++ in a while, so I will just skip it.
    Edit: Also, thanks for the FFMpegSource tip, I am using that now for CCE and no crashes ever since.
    Apr 2006
    Originally Posted by [url=https://www.videohelp.com/tools/QuEnc
    Quenc[/url] Settings]
    Top Field First
    this sets field order to TFF when ticked. field order is BFF when not ticked.
    I am trying to clear one thing up about the above setting. Should Top Field First and Bottom Field First be disabled when Interlaced is not checked? Based on Jman's comments, it would seem this should be the case when Interlaced is not checked.
    For now, I am going to assume the explanantion in the settings document for TFF only applies when Interlaced is set.
  6. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    If interlaced is not checked, TFF/BFF is ignored.
    Buy My Books
    Apr 2006
    Thanks gadgetguy.
    My next question is regarding the QLB option. The documentation and the GUI is not very clear. I am going to assume that when you choose "QLB" that you don't necessarily have to choose Custom Matrix. But if you choose Custom Matrix, you are automatically choosing QLB.
