I am trying to put an .avi file on DVD using DVD FLick. I used to use NERO but no longer have that product. Anyhow, when I create the DVD files using DVD Flick, and try to play it on my player (U.S.) I get a region protection error. Never had this before and the .avi file certainly didn't have a region encoding on it unless my panasonic home video camera mysteriously got one last week![]()
Any ideas? Or any other shareware that can put .avi files to DVD without this region error (I am assuming it's a DVD Flick issue)
I'm guessing your video is PAL format, not NTSC. Check the framerate on one of the VOBs with Gspot or similar. Burned DVDs don't have regions unless you put them in, which would be unusual. Players may give the 'region' error if the framerate is wrong.
You can use a program like ConvertXToDVD or FAVC to convert the framerate. Or DVD Flick probably has that option. -
Read my blog here.
You are RIGHT ON as far as it defaulting to PAL. I am going to try changing it to NTSC tonight and giving it a try. Hope that's it. I'll let ya know and as always...thanks!
Good deal.
That problem is also fairly common with videos off the net. You really need to check on the framerate before and after converting if you are having similar problems.
Not surprised it was the PAL encoding at fault...
My Sony player gives the "playback prohibited due to region limitations" message on PAL discs even when they have no region coding on them at all!
Samsung BD-P1590/BD-P1600 Foreign Firmware Flash/Region Free Issue
By 5arge in forum DVD & Blu-ray PlayersReplies: 12Last Post: 15th Apr 2012, 19:32 -
Samsung BD-P1600 region hack & Sherlock Holmes Blu-Ray issue
By Mighty_Morpheus in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Aug 2010, 12:09 -
DVD Flick & ISO size issue
By jnojr in forum Authoring (DVD)Replies: 8Last Post: 6th Jan 2010, 18:57 -
Samsung DVD-R150 region free issue.
By h3ine in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Nov 2008, 09:48 -
DVD Flick issue
By saspgmr in forum Video ConversionReplies: 7Last Post: 17th Aug 2007, 06:05
