Whenever I choose a picture as wallpaper in my WinXP desktop the description has a fixed color background as shown in the screenshot below:
How can I get rid of the green background so that the icon letters lay directly on top of the wallpaper in a transparent fashion? Thanks
	the desktop setting is found by right clicking my computer/properties/advanced/performance/settings/visual effects - either select adjust for best appearance or at least make sure use translucent selection rectangle is checked. --
	As per aedipuss but check "Use drop shadows for icon labels on the desktop" if you mean you want all icons to have transparent text, not just highlighted ones. John Miller
	aedipuss, thanks but that did not change it. Anyway it's cool to know that I can access visual settings using your suggested route. I was always trying to unsuccessfully change this by rightclicking the desktop/Properties/Appearance.
 JohnnyMalaria, that worked great. Now my desktop icons look great! Here is a screenshot of the same icon after the setting change:
 Regards and thanks again!!!
  How much do you customize your desktop?By johns0 in forum PollsReplies: 6Last Post: 4th Oct 2010, 17:38
  Woopra Desktop Client 1.4 on WinXPBy connorabb in forum ComputerReplies: 5Last Post: 27th Aug 2010, 10:34
  No desktop icon or Start menu with MPC Classic?By mikehende in forum Newbie / General discussionsReplies: 9Last Post: 29th Mar 2009, 19:54
  Remember your desktop icon layout for WIN XP..like win95 ezdesk? [RESOLVED]By vhelp in forum ComputerReplies: 6Last Post: 7th Jan 2009, 11:22
  How to get rid of *#@% AOL icon from desktop??By Forum Troll in forum ComputerReplies: 2Last Post: 30th Oct 2007, 12:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
