I am starting to burn a lot of VCD's, SVCDS and especially home video editing. I would like to keep the jewel cases looking the same so I have decided to go w/ the DVD look. Now, SVCD's generally uses at least a couple of CD's if not three.
Does any one know a good site that sells the inexpensive Double DVD cases or similar items?
Finally, what is everybodu else doing to store their SVCD's in the entertainment center? Regular jewel cases? [/b]
Use Fellows CD Sleaves. You can get 50 double sided sleaves for $5 online (use pricegrabber). You can fit 1 movie in 1 sleave.
CD Sleave:
Advantage: soft felt backing to wipe away fingerprints, small footprint (fits in folders, back pockets, etc), fairly inexpensive ($0.10 per sleave), durable (doesn't break or rip easily), snuggly holds 2 cdrs perfect for 1 movie.
Disadvantage: small area to put graphics (you can slide in a print out of the title at the top of the sleave).
Solution for small label area: print out cdr disc labels to stick on the cdr itself.
CD Cases/DVD Keep Cases:
Advantage: looks like a retail product, big area for sliding in graphic covers.
Disadvantage: expensive (especially for 2-3 disc holders ~$2+ for 1 case), easily cracks, center part disc holder chips/breaks if dropped. -
I use those cd cases that hold 3 cd's. They do alright. Do a search on yahoo and you'll find plenty of places selling them. Also check on Ebay.[/b]
my local comp store sells real nice quadruple jewels that are as thin as normal store bought 1cd jewels only prob is that if you want to put graphics you have to stick it on the exterior
I really like these:
http://www.bestbuy.com/detail.asp?e=11042363&m=488&cat=516&scat=517
Imation 700MB with Thin Jewel cases (and cases are what we are talking about); usually about $10 for a 25-pack. They burn great in my Philips PCRW2010. You can get the boxes separately, but they actually cost more that way. I could probably find them cheaper, but Best Buy never did me wrong on a mail order yet.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
CD Jewel Case Cover Creating software....
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 16th Jul 2011, 16:17 -
Verbatim DVD+R 100 pack vs. DVD+R single jewel case
By GSP_87 in forum MediaReplies: 6Last Post: 13th May 2011, 05:00 -
need a jewel case for microSD cards
By mrtunes in forum MediaReplies: 2Last Post: 19th May 2009, 07:42 -
DVD/CD Jewel Cases
By wulf109 in forum Off topicReplies: 3Last Post: 23rd Jul 2008, 17:13 -
CD Jewel Case Inserts...best pricing?
By ChaunceyK in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2007, 14:10
