I am trying to make a copy of a dvd I own using DVDFabplatinum on my Vista laptop. I keep getting coasters though. The DVD skips at the end of the movie. I use VSO inspector to scan the burned DVD and it finds the bad sectors at the end of the burn. I have used two kinds of media Verbatim and Memorex, but have the same poblem both disks. Any ideas on how to remedy this problem? Any help would be appreciated.
Peace...
I used imgburn to burn instead of dvdfab. I am still getting the error codes at the end of the burn. The disk works though. This is happening at slow burn speeds as well. Using my xp desktop and my vista laptop. Is this normal? I set VSO to check the last sectors first and it is showing errors at the end of the disks every time.
Sounds like you are using cheap media or a media that your burner doesn't like.
Google is your Friend
openSUSE 10.3 Linux, Wine & DVDFabPlatinum [SUCCESS!!]
By burpnrun in forum LinuxReplies: 3Last Post: 11th Jan 2008, 14:45 -
DVDFabPlatinum
By crowheart in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 21:40
