Hi,
I have gone over most of the threads, used the tips and the programs (WM Recorder, VCL, SDP downloader, Net Transport, ORBIT, and REAL player) but have not been able to get the file bellow.
This wmv file is ina site for which i have the username and password.
The main problem is that none of the programs above are able to get the wmv file.
If you guys (gals) have any ideas or direct me me to the rigth path, please share!!
Thanks!!!
Is there room for one more?
HELL YEAHHH!!! -
Did you try WebVideoCap or maybe VideoCacheView?
HELL YEAHHH!!! -
Without the address and the username/password, we can't be of any help at all.
The only thing I can suggest is a screen capture software.
EDIT: I didn't see any mention of Urlsnooper2 in yout first post. I doubt it will work either but might be worth a try. A lot of websites make it impossible to get the movie file. -
After file loaded and played, did you check your temp internet file folder?
You should see the file in that folder.
Tools->Internet Options->Browser History: Settings->View Files -
Not necessarily, you can define the length of time a file should be cached or if it should be cached at all by the browser.Originally Posted by LJB
http://www.google.com/search?hl=en&rlz=1B3GGGL_enUS249US249&q=http+Cache+Control&btnG=Search
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 7th Sep 2012, 00:42 -
trouble ripping SWF or FLV from a website
By blacksheepdownunder in forum Newbie / General discussionsReplies: 13Last Post: 1st Aug 2010, 06:57 -
What is the average time of ripping a dvd file to an AVI, or WMV
By ManhoefDream in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2008, 15:49 -
ripping video from a website .... to australians
By lóreal in forum Video Streaming DownloadingReplies: 21Last Post: 26th Apr 2008, 08:24 -
wmv to flv - 3 possible conversion with ffmpeg- difficult choice
By bmb in forum Video ConversionReplies: 0Last Post: 1st Oct 2007, 16:00
