I've been doing video capturing for quite some time on my desktop system using an Osprey 2000D DV Pro capture card. I just recently got a Canopus ADVC110 for my laptop, so I could do short captures using the convenience of a laptop.
Using the same software on both machines - VirtualDubMod, VirtualVCR, Vegas; have experience with all three on my main rig. The ADVC110 shows up in my Hardware Manager (running XP Pro SP2) indicating that it's operating properly. Problem is that this device does not seem to show up as a selectable device in any of these programs. The only thing that shows up is some kind of Microsoft Capture device. I'm sure I'm missing something obvious, but how do I get this device to be visible and selectable from these programs?
Results 1 to 17 of 17
It will not work with VirtualDub anything nor VirtualVCR but it should work with VEGAS so I don't know what the issue there is ... I would try WinDV or DVIO or maybe even ScenalyzerLive if all else fails.
I don't why you can't use VD or if you can however any program made for capturing DV will be suitable, even windows Movie Maker. The resultant file will for the most part be identical no matter what program you use. The only way they differ is some options like splitting by scene, file size, type 1 or type 2 DV... all really minor things.
It shows up as a standard DV device here. I'm not sure whether my PC knows it's an ADVC110 specifically or not - I've never looked. Anything that can capture DV video (e.g. from a camcorder via firewire) can capture from the ADVC devices - they look the same to the system.
Cheers,
David. -
The Canopus is a hardware DV encoder similar to the Plextor device except thats a MPEG encoder, any capture program that supports DV will be able to utilize it. e.g. if the capture program can capture from a DV cam it can capture from the Canopus. The video coming across the firewire is already encoded to DV, the "capture" program is really nothing more than a middle man that allows you to save the stream to disc.
There might be a few programs that can't capture with it but its really irrelevant since there is so many available. -
David, how exactly is it identified and which capture program are you using?Originally Posted by 2Bdecided
It's on my home PC so I can't check how it's identified, but it works with WinDV, Vegas, some Ulead software (not sure what - came free with the Firewire card), Windows Movie maker etc - anything that works with DV.
My preference is WinDV, because it's reliable.
I might have seen it called "Microsoft DV" or something like that in one program maybe - I can't really remember.
If you give the ADVC110 a video signal and plug it in (6-pin Firewire includes power supply - won't work if your Firewire card doesn't send power down it!), Windows should pop up a window asking what you want to use to capture that video (unless you've disabled this message box previously).
Cheers,
David. -
Install XP SP3. My laptop wouldn't recognize my camcorder until I installed SP3.
Buy My Books -
gadgetguy, XP SP2 does recognize the ADVC110 as a video capture device. I think the suggestions regarding using the correct software are probably the right ones.
So the question is: what programs other than Vegas and MS Movie Maker are able to work with DV capture devices?
And am I still limited to DV capable software if I use the analog inputs to the ADVC110? -
You had your answers with my very first post in this thread ... the very first response.Originally Posted by tonyp2
What more do you want?
And yes you are restricted to DV capable software as you have a DV only piece of hardware although there are some "convoluted" ways to capture direct-to-mpg yet I would say NO to those methods as it is not how that device was made. Capture DV AVI and then do with it whatever with it afterwards (be it conversion to MPEG-2 or DivX or H.264 etc.)
Some of us don't do this for a living, John. While I do have and use an Osprey 2000D, that reality hardly makes me all-knowing in these activities. My confusion lay in being able to use tools like VirtualDub in capturing data from the Osprey when fed through its analog inputs, but not being able to do the same with an external Canopus. I can only presume that the drivers supplied with the Osprey (or any internal capture card, I suppose) is what allows them to be used with these VfW or WDM -capable programs. Confirmation, guidance, and correction is all I'm looking for.Originally Posted by FulciLives
If your input is analogue beit it from a VCR or a non-digital camera then you plug your analogue cables - audio and video into the ADVC
The cable into the PC should be a firewire becuase if you connect analogue cables into another capture card then you are just using the device as pass-though. Then the other device is doing the capturing and not the ADVC.
Many programs will see the ADVC. I use Ulead Video Studio, Ulead Media Studio, Ulead DVD Movie Factory, Ulead DVD Workshop, Vegas. I've also done demo captures with Cyberlink Software. And Evem Windows Movie Maker.
Most see the ADVC as either "Unknown -MSDV' or 'AVC Compliant Device'. If you do not have another capture device then under Movie Maker it should select it automatically.
Just one thing. I do not have a ADVC 110. I use a ADVC 300 and that device has a button on topic to switch from a digital input to an analogue one. If the 110 also has this button, that could make some difference. -
The reason for the non selections is DV is a set bitrate, DV is DV, it doesn't deviate. The only thing that can differ on it is the frequency of the audio and I'm pretty sure the Canopus doesn't allow for that. Been a while since I used mine so I'm not sure. It's common on comcoders to have a selection for this. FYI if you get a camcorder they usually default to 12 bit(32khz). Be sure to change it 16-bit(48khz).
The card like the Plextor which does MPEG would have selections because MPEG allows for different bitrates, resolutions etc.
Other cards that do not do hardware encoding will allow for any format but generally these are never as good as hardware encoder for a specific format. -
My point was I confirmed all this in my first post. I said it won't work with Virtualdub anything nor VirtualVCR and what programs it will work with.Originally Posted by tonyp2
Granted I didn't go into a lot of details and by no means was my list comprehensive but I did give you 4 options that work (Vegas, WinDV, DVIO and ScenalyzerLive) and yet after my post and all the other posts you are still asking for WHAT PROGRAMS WORK ... duh duh and triple duh are you freakin' daft or what ???
It's like you never read my post at all ... or any of the other posts. Hell look at the post by 2Bdecided who confirmed ...
Oh forget it ... obviously you can't read well and/or are dense.
Although it's been ages that I've used my canopus advc 100 I did use ScenalyzerLive. It worked well with my canopus advc 100. I had that Panasonic dv codec installed as well when I did capturing with my canopus advc 100.
https://www.videohelp.com/tools/Panasonic_DV_Codec
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 18:23 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 17:09 -
ADVC110 to Studio 10 Capture
By jimlong in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2008, 09:41 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Possible to capture hd from hdvr using ADVC110?
By john22 in forum Capturing and VCRReplies: 6Last Post: 2nd Aug 2007, 22:09
