Where is that dead pixel ?
If it is in a place that is in direct view of the user, then you are going to get mad, else....
Note: One of my dell 22" has 4 stuck pixels, but they are all at the lower left hand corner, so they did not eik me.
Results 31 to 43 of 43
I'd suggest trying the "massaging" technique. My warning about breaking anything is just me being practical. Most of the people that I've seen post about it were successful doing that and I haven't seen anyone post that it screwed anything up.
Thanks for the suggestion and sorry I haven't replied but I've tried that every day since it was posted. I'll continue to try it and keep my hopes up.
I know it's only one pixel but I've always liked Dell because of the quality and am completely surprised by this and their lack of help. -
Dead I can tolerate, Stuck on I hate.
Return the monitor and move on.
Don't waste time trying to get them to Exchange it. Before you know it you won't have any returnability and they won't fix it under their dead pixel policy. -
How do I know the difference? Since it's bright blue and not black I'd assume it's the latter.Originally Posted by TBoneitI bought it on eBay, the seller is telling me to return it to Dell.Originally Posted by TBoneit
I've had two dead pixels on a 23" Westinghouse, but they both "came back to life". I have not had a problem since. I don't know why.
I don't buy Dell. I have had bad video cards on Dell and know three people who's HD's went out. I have found that Dell buys low bidder components and then offers a warranty. I don't want the problem in the first place. The pixel policy is just not acceptable from a reputable company, but I don't consider Dell reputable. In my opinion, they are just a low cost volume marketer.
I swear by HP workstations. I currently own four HP workstations with dual HD's. I also bought one for my son and one for my daughter. HP workstations are affordable and super high tech. The latest Intel chip sets with fast bus speeds, etc., - professionally designed. You won't find them in retail stores. Take a look at hp.com -
If you try massaging it you may be able to move it out towards the edge of the screen . This does require a lot of work and a steady hand.. at first it will appear not to move, but if you rub it from different directions you should dislodge it. Then gently push it out to the edge of the screen.
LCD mon (or tv) is the only product I always advise my friends to actually buy the extended warranty (if the store doesn't have "no questions asked refund/replacement" policy, which anyways usually is waived regarding LCD products).
My first brand new iPAQ PocketPC had a dead pixel almost exactly in the center.
Of course HP didn't want to replace it, not unless there were more of them (5 or 8 IIRC,)
I had to resolve to different ways and have it sent to them broken the way it looked like manufacturing problem just to enforce my consumer rights to have working product in exchange for my monies - it really was the only way to receive working product as replacement. So ridiculus.
As consumers we have right to receive problem-free product, and monitor's dead pixel (or any device's with a screen) is equal to broken device; it is not not like scratch or missing screw on the bezel or something - it is THE most important feature of the monitor since we buy them only to look at their screens! I never understood how they can get away with it, and there never was any class-action suit against them IIRC. -
Now make that two bad pixels, the bright blue one stuck on (top center) and today I now have a black one that is dead (lower right).Originally Posted by moviegeek71
If you don't know how to make it appear with more dead pixels just search the web... simplest is using distilled water poured through vents to fry it - but I don't recommend it since you may fry yourself if you pour it onto power supply
Anyways, search the web.
There is no shame in doing so. If a company can't give you properly working product while they took your money - any trick to get your money back or force them to exchange the product is as good a remedy for their worthless "warranty" as any other.
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 10:42 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 14:53 -
Dead Pixel on LCD Tv- Can it be fixed?
By Super Warrior in forum ComputerReplies: 9Last Post: 2nd Aug 2008, 01:08 -
Bad Pixel. What comes next?
By videobread in forum ComputerReplies: 5Last Post: 8th Mar 2008, 22:07 -
Why would the bits/pixel drop?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 8th May 2007, 04:55
