I have a DVD which is home movies, so there is no copy protection issues with the DVD itself.
The problem is the audio is too low, so I want to demux the audio files from the DVD, process them to increase the volume, and then integrate them back to the DVD and reburn it.
I have a program for increasing or normalzing audio files, so that is no issue for me.
My question is, what software/utility is out there that will allow me to extract just the audio stream, and also add it back in once I am done modifying the audio files so I can re create the DVD.
If it matters, the audio files are AC3
Thanks.
Use pgcdemux to demultiplex the video and audio files.
Edit the ac3 file.
Add back the original video and thew new audio using muxman.
Add back the menus using vobblanker.
Guide https://www.videohelp.com/guides/simplistic-guide-for-replacing-dvd-streams-flash-id937#937 -
Thanks for the response. I will go have a look at these utilities.
What I can also tell you (since my original post) is that I was able to demux the AC3 files out using DVDDecrypter. Another thing I want to mention, is that I do NOT need to modify the menu audio (it is fine). I only need to modify the main movie section audio.
That being said, is there not some simply utility for REMUXing VOB files as easy as it is to demux them? If there is, and I am able to recombine the video section and audio section of the VOB file, can I then just simply reburn EVERYTHING back to a blank DVD?
What I am getting at, is if nothing at all is changing other than the audio level (no time change, no file change) do I need to mess around with manually adding the menus and hooking chapters back up?
Thanks! -
No, you don't have to manually remake the menus. In vobblanker you load the old movie and just load the new created vobs from muxman and make a new dvd. Watch the guide!
Thanks. I will have a go at this today and let you know how I make out.
What is the easiest way to add or replace existing audio DVD sound track
By pwangdel in forum Authoring (DVD)Replies: 18Last Post: 2nd May 2011, 02:10 -
The easiest and faster way to add a watermark in my video
By morsino in forum Video ConversionReplies: 9Last Post: 10th Jul 2010, 09:51 -
add subtitles using AVI Demux problem
By pensioner in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2010, 03:12 -
Easiest Way on Mac and PC To Make Audio CD From DVD
By MacPCConsultants in forum DVD RippingReplies: 2Last Post: 26th Feb 2008, 08:18 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35
