I have an mpeg2 clip that is 59.94 progressive. However, the source is actually interlaced being forced into progressive (commonly done in new digital cable channels).
When looking at this clip frame by frame, I can tell they double the lines of the original fields to make a frame.
How can I take one frame, throw away the even lines, use it as odd field, take the next frame throw away odd lines and use it as even field... and end up with a 29.97 interlaced mpeg2 (or avi) clip, so I can make a normal DVD out of it?
I have premiere, after effects, tmpgenc..., if they can be used somehow to do this
You should be able to do it with Avisynth using SeparateFields(), SelectEvery(), and Weave().
Buy My Books
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 10:22 -
Interlaced video interpreted as progressive in mkv container.
By Gothic Autumn in forum Video ConversionReplies: 12Last Post: 12th Dec 2010, 21:04 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 17:41 -
Convert Interlaced video to Progressive?
By ziggy1971 in forum Newbie / General discussionsReplies: 21Last Post: 20th Sep 2008, 20:33 -
Does de-interlaced video = progressive?
By yoda313 in forum RestorationReplies: 13Last Post: 18th Aug 2008, 20:51
