Hi. I'm trying to get the AC3 files from the menus via DVD Decrypter, but the menus aren't showing up in the program. I also tried Smart Ripper, but it the program won't display them either. I tried DVD Shrink and it displayed all the menus just fine, but I'm not able to get the AC3 files from the menus. Is there a setting I need to change in DVD Decrypter or Smart Ripper? Thanks.
If you set up DVD Decrypter in File Mode (not IFO Mode as you seem to have it now), you'll see all the DVD files and can highlight just the one with the menu for decrypting. You can even go into Stream Processing and get just the AC3 audio out of the menu, or you can decrypt the Menu VOB to the hard drive and extract the menu audio from that using a number of methods (I use DGIndex).
How to force subtitles to be shown in certain parts of the DVD?
By dexter30 in forum SubtitleReplies: 1Last Post: 24th Jul 2009, 20:58 -
X264 GUI Shown On The Tutorial
By Cunhambebe in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2008, 22:11 -
Cyrillic subtitles not shown corectly on DVD player
By uher in forum SubtitleReplies: 1Last Post: 10th Dec 2007, 15:05 -
DVD Decrypter problems - I want the very best DVD ripper
By Lovepeaceguru in forum DVD RippingReplies: 3Last Post: 11th Nov 2007, 20:54 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
