I wanted to ask some basic questions.
I am only familiar with AVISource and DirectShowSource, but want to become familiar with others. Here are my questions:
1) How do you disable the audio when using FFMpegSource and DGAVCDecode?
2) When using DGAVCDecode, do you have to use a dga as your source can you use the traditional file extensions (avi, mkv, ogm etc etc)
3) When using an Avisynth Plugin, how come some of the Plugins have to be in the AviSynth Plugin Directory and others can be anywhere? Is it based on how the software was developed?
only dga index files. from loading input into DGAVCIndex.Originally Posted by Maikeru-sama
valid inputs for DGAVCIndex are elementary h.264 streams or h.264 transport streams.
so...
for all the formats you mentioned, demuxing comes first.
there is no audio with dgavcdecode.Originally Posted by Maikeru-sama
the audio is off by default with ffmpegsource.
all plugins can be anywhere.Originally Posted by Maikeru-sama
(* although some may depend on libs that need to be placed in your path)
plugins in the plugin directory are autoloaded, ie loaded each time you call on a script.
and are available to you to call with a simple: plugin()
plugins external to the directory (and c plugins) have to be manually loaded in each script,
ie loadplugin("plugin.dll"), and then a call to it: plugin()
tripp"I'll give you five dollars if you let me throw a rock at you" -
FFmpegSource is for video only, and FFAudioSource is for audioOriginally Posted by Maikeru-sama
The difference between DirectShowSource is because it deals much better with different codecs configuration, it works much like a Graph for render any movie directly connecting pins, much like FFDSHOW.
Not all people uses FFDSHOW, but rather they use CCCP which for me is much better because it is a light version of FFDSHOW and just works fine, or they use CoreAVC. FFDSHOW mega pack can ruin your PC if you don't know how to configure and deal with it...and few people knows about it
It easy to figure that out when there is 1000 computers with different codecs configuration : they can play, therefore they demand a successfully conversion....they just don't care about anything
speed, and one-click conversion, is just what they want
Code:2) When using DGAVCDecode, do you have to use a dga as your source can you use the traditional file extensions (avi, mkv, ogm etc etc)
for DGAVCDecode, never used it, FulciLives would answer
They can be automatically loaded, or manually3) When using an Avisynth Plugin, how come some of the Plugins have to be in the AviSynth Plugin Directory and others can be anywhere? Is it based on how the software was developed?
Since there is many plugins, each application loads manually the plugins by their own way -
Good stuff gents.
One final question (I didn't ask because I need to know the DGA question), is there a command line tool that will encode files to DGA? -
index you mean.
dgavcindex has a cli mode.
read the manual
You're not encoding your files to dga, all you're doing is creating an Index which points to your h264 source file. When you load that index (the dga file) into Avisynth (via the DGAVCsource command) it will provide the necessary information for VirtualDub (or whatever app you want) to convert to another format.
Download the avchd_convert zip file in this thread if you want some help with the command line syntax of DgavcIndex
https://forum.videohelp.com/topic346331.html -
@Soopafresh, I will download that when I get a chance and of course, ask questions, if I have any.
Also, finally got around to downloading the FFMpegSource Plugin and I have encoded about 5 MP4 files in a row via Avisynth and CCE has not crashed yet
So it looks like I will be using the FFMpegSource for files that are of the same criteria of the sample most in here is familiar with.
Also, does anyone know if the developers of Quenc frequent this forum? I am in the process of writing a Batch front-end to it, which I would like to share with the forum and I would like to be able to program the "pulldown" option they have in their application with it but there doesn't seem to be a command line argument for it in the quenc notes.
Based on my limited knowledge, it seems like Quenc internally determines if you need it, not sure though.
But anyway, I don't want to derail this thread, so I am going to split. -
basic video questions
By Dan K in forum Newbie / General discussionsReplies: 17Last Post: 2nd Jan 2009, 16:59 -
Basic question about AVISynth plugins
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2008, 11:04 -
A few questions about ChangeFPS, FFMpegSource and 25.689 Framerate
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 30th Jun 2008, 19:02 -
Basic FFMpeg Questions
By Maikeru-sama in forum Video ConversionReplies: 8Last Post: 7th Jun 2008, 09:33 -
aviSynth + CCE Basic (2.7) fails on certain scripts
By binister in forum Video ConversionReplies: 6Last Post: 11th May 2008, 00:23
