  1. Is there some freeware (optimal) editing-application where you easy can add a slowmotion area where you decire in movie-clip
    And allso add a repeat area, and let thoose frames repeat 2-89 times :P until finally release..and moves on playing normal!?
    certanley not Windows movie maker atleast
  2. Some trialware then?
    ..thath i get klick instructions is the most important
    tnks
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Vegas, Premiere - pretty much any good editor. But it will also take a lot of work. Nothing automates that type of effect that I am aware of.
    You could also do it with avisynth is you are patient enough to learn how to script.
    But I don't know of any quick, one-click answers.
    Read my blog here.
  4. Ok, thanks for answer
  5. Member ks47's Avatar
    May 2007
    Originally Posted by Blå_Mocka
    ...certanley not Windows movie maker atleast
    If you want use WMM, as I recall I needed to frameserve the movie clip to IMPORT INTO COLLECTIONS for mpg files. You can slow down ½ speed in WMM with TOOL>VIDEO EFFECTS>SLOW DOWN, HALF. Also you can repeat a segment by copying and pasting however many times you want it repeated.
    If you want to do in VirtualDub (with plug in)/ VirtualDubMod for mpg files, here is a direction in recent post:
    https://forum.videohelp.com/topic288508.html
    Or this YouTube tutorial:
    http://www.youtube.com/watch?v=ahEt8XY2RYE
    You can trim and append the video segment for what you want to do.
    TS
