    Feb 2002
    Omaha,NE
    Just having a problem with the sound and the video arnt in syncrinization. The sound is about a half second before the video. This is in the mpeg i get after using TMPGE. Any help would be appreciated
  2. Right here on this very site:
    http://www.vcdhelp.com/sync.htm
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. there is an easier way by opening the settings and going into the advanced tab you can check off source range then double click it to find the audio gap correction setting that can be used to move the sync of the audio back or forward. this is how you correct a skew but if the audio gets progressivly more and more out of sync you will need to use the method in that link.
    peace out,
    dumwaldo
    AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
