Here is my current problem.
First I split the 7G mkv file into 2 chunks so each chunk will fit into a DVD5 ie 2 vob's one 4Gb the other 3GB
Then I created the IFOs with IFOedit for each of the video streams separately.
After creating the IFO , I tried burn them with Nero Express and immediately run into problem of too large file as each file is larger than 2GB . So I used Image Burn to create the iso and burn the DVD. However the the iso image will not even play using VLC player or any other s/w player in the computer. Yes I did change the language to English in the IFOs. What did I do wrong ?
BTW there are so many audio and subpicture streams that it took a long time to change them all to English . Do I have to change the subpictures to English even if I dont need the subtitles ie can I leave them unassigned?
TKs
Please describe exactly what you are doing and what software you are using. It sounds like you split the mkvs and making ifos for mkv files...and that is not possible.
I would instead try other all-in-one converters like ConvertXtoDVD, DVD Flick or FAVC.
And MKV to DVD is video conversion and not editing. Moving you. -
I solved the problem by using Nero Vision to create the DVD file structure from each of the split vob's and burning them .
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
How to Create MKV Videos
By dhyane in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 05:52 -
Create DVD from mkv and retain size?
By elven in forum Authoring (DVD)Replies: 1Last Post: 7th Apr 2008, 05:15 -
How do I create an MKV from AVI files?
By cyber0ne in forum Video ConversionReplies: 3Last Post: 20th May 2007, 08:13
