some times I post my vids
I use MacPar Delux then Osiris to post them
I usually use the Y-Enc encoding on Osiris
once I forgot and it had no encoding
in this day and age w high speed, what is the advantage/disadvantage of encoding or not?
cheers
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Usenet servers are like a big peer-to-peer network, where they copy posts from each other. This only works reliably if the servers all speak the same 'language'. Like with most internet messaging systems, some (non-printable) characters are reserved for special purposes or have a special meaning. Encoding takes care of that, and yEnc in a most efficient way (little overhead). Encoded binary attachments should not corrupt as easily.
Forgetting to set an encoding type for a binary attachment should result in encoding it anyway with some default method (maybe QP?) to avoid corruption. I said 'should', because it is up to the programmer to implement that. -
thanks
sometimes I post w Unison
any idea if Unison encodes?
thanks MuchlyMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
New Motherboard is not POSTing...
By Stealth3si in forum Media Center PC / MediaCentersReplies: 19Last Post: 20th Jan 2011, 16:36 -
HELP - New motherboard not posting
By beavereater in forum ComputerReplies: 15Last Post: 18th Oct 2008, 16:21 -
HELP encoding vids to play on Chinese import MP4 player
By MajorSmith in forum Video ConversionReplies: 4Last Post: 15th Jul 2008, 12:19 -
Error in posting?
By moviebuff2 in forum FeedbackReplies: 2Last Post: 5th Feb 2008, 19:15
