got this moving straight lines in my crt monitor in the task bar part. Is my monitor dying?
	hacking the Net using typewriter :D
	Could be the monitor itself or simply interference (on the AC or the video input). However, if the "lines" are staying in the same place, it is likely the monitor. Google is your Friend
	it's the same place. sometimes it disappear. hacking the Net using typewriter :D
	The easiest way of troubleshooting, would be to test the monitor on another computer (preferably at another location). That would eliminate the current PC and AC power as culprits. Google is your Friend
  Can I use a headrest monitor as my server monitor when travelingBy regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43
  Need New MonitorBy mccoady in forum ComputerReplies: 13Last Post: 7th Mar 2008, 16:33
  Where do these lines come from?By RedFarmer in forum Capturing and VCRReplies: 8Last Post: 6th Nov 2007, 07:13
  What are these lines?By Dr.Gee in forum Newbie / General discussionsReplies: 14Last Post: 14th Sep 2007, 14:17
  LinesBy snake2589 in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 20:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
