I have a recently purchased a 4GB MicroSD card and i cannot read in my PC's card reader. My Palm Centro reads it fine but I get a lock-up when I plug into my multicard reader. I suspect that there may be a problem with my PC reading this large card since it is relatively new on the streets. Does anyone have an idea about what may be going on? I am running Windows XP Pro.
Thanks in advance,
VC
This is so much fun!
Some card readers have issues with the newer cards. Make sure your reader can read the card type. I had to buy a nw reader when I got an SDHC card...Good Luck
Thanks for the tip. Maybe I can I find a USB one that I can plug in when I need it.
This is so much fun! -
You can get an excellent hc card reader at dealextreme.com for about $3 shipped. Works great with those cards.
Upgrading my comp, any suggestions?
By evervoid in forum ComputerReplies: 4Last Post: 22nd May 2011, 16:10 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 06:39 -
Where do I put the ffmpeg 5.0 at on my comp?
By HaukkeIV in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2010, 02:00 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04 -
Would my comp be able to add an other hdd ?
By StoneColdWhat in forum ComputerReplies: 13Last Post: 8th May 2007, 12:19
