Recently backed up my DVD The Eye. Extracted with Defab 5, was able to wash it through Shrink to get better quality. Watched it on my computer using Media Player Classic. All was well. Copied it to DVD, hung in one spot. Alert from DVD player said "attempting to read media" then continues to play after a few seconds. I decided to burn another copy to see if the first copy might not have copied correctly. Hung in the same spot for the same amount of time, then continued to play. Any ideas why this may have happened and how to fix it???? Thanks
same batch of discs? could be a run of bad dye in that area. try another brand/or spindle.
dvd area codes
By Arthurbrian in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Mar 2010, 23:12 -
DVD Studio Pro 4 - Subtitle area width?
By Geiger9 in forum MacReplies: 1Last Post: 6th Feb 2010, 21:44 -
portable DVD player cracking sounds then hangs
By dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 06:29 -
dvd rip to avi with black area
By maxmaxx in forum DVD RippingReplies: 2Last Post: 5th Jan 2009, 17:19 -
Slow motion FX hangs DVD players
By Canopus Smoker in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2008, 16:18
