my mom deleted stuff off the hard drive.. so i went to install windows 98, and it told me to run scandisk first the restart my computer.. so i did.... and well now when i turn the computer on, all it says is invalid disk strike key then its got the A:/ underneath of that
it will only run my A drive ... its all f(*ked up now
my friend has that problem.
Now what should she do
apparently the Windows 98 boot disk don't work.
is their a dos command to format C from the A:/ prompt
FORMAT C:
However, only do that if you do not want any of the data contained on the drive.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Need some quick help with IMGBurn
By flyin-lowe in forum Authoring (DVD)Replies: 4Last Post: 8th Dec 2010, 19:20 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 17:14 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Help On Audio
By dbanga in forum AudioReplies: 2Last Post: 17th Jun 2007, 15:35
