Bought a cheap nasty Umax Kazuki 2800X about a year ago, but it's now having trouble reading discs.
Recently bought a Sony NS36 as a replacement, but found out that it won't play my widescreen DivX/Xvid files correctly, and puts black bars on the top and bottom of the screen, so I returned it.
Having searched these forums, I've found that seems to happen with a few players.
Any suggestions for a player that will play them properly out of the box like my old Kazuki did?
I know it's sometimes fixed by changing PAR settings or something, but as I have a lot of files already burnt to discs that's something I'd like to avoid if possible. Ideally need something under £40, but I'll play extra if it's particularly good.
Not fussed about HDMI or upscaling or stuff like that, as I don't have an HDTV, and no plans to upgrade soon.
Thanks.
	Your best bet is to simply take a disc with you to the store and test them yourself. It's possible the issue is with your files and the Sony was working normally. In which case, all of the responses that you get here will likely be for other players that function similar to the Sony and will further waste your time. Google is your Friend
  My DivX DVD Player can't play my avi DivX/xvid videoBy Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11
  Suggest decent, cheap DVD player for divx/xvid/mkvBy Batchman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th Mar 2012, 17:33
  Decent DVD recorder that plays AVI (DivX & XviD MPEG-4) w/HDMI out?By perceptionist in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Feb 2012, 20:20
  Best Divx Ultra DVD Player with Full file Names for MP3 and DivX FilesBy MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00
  3gp to avi decent quality requires iTunes, Dr DivX and Virtualdub!By Dannyfoster in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2007, 16:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
