    Jun 2008
    I installed XP Pro with SP3 onto my new machine. I was playing AVI files using Media Player with no problems.
    I installed the K-Lite mega codec pack and now whenever I get the ffd audio and video icons in the lower right corner I get a 1/2 second video lag behind the audio.
    This only occurs when the FFD boxes engage, and I assume this means they are running a codec that needs the ffd programs to run.
    Since the files played fine without this ffd, is there a way to turn it off or switch it back to the original default that media player was using before I installed the mega codec pack ?
    Thanks for the help
    Bill
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    That is the major drawback of installing codec packs. Try uninstalling the codec pack (which has a 50/50 shot of fixing the problem) and then only install whichever codec(s) you actually need for your files as needed.
    Google is your Friend
