Hi All
I have a NVidia Video card installed that claims to have TV out.
I am trying to hook the machine upto a Chroma key box via the nvidia svid connector.
All works fine except I cannot set the S-Vid output resolution to 720x576 (PAL) as required. I have use an ATI card before and not had this problem.
Is there a fix for this on the NVidia card, or should I just go buy an ATI card?
Many thanks
Vert
What resolutions can you choose? Have you tried any of those and they don't work or?
You can try use a third party software to change resolutions like Powerstrip, http://www.entechtaiwan.net/util/ps.shtm .
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09 -
*.vid Format video? conversion help....
By slm_satish in forum Video ConversionReplies: 4Last Post: 20th Apr 2008, 21:30
