http://www.visiontek.com/everything.shtml
Xtasy Everything is what it's called...it sales for about 190.00$. It says "real time mpeg2 compression" in the description, does anyone have any more information on this card, or experiences? Thanks!
No, its not a hardware capture card... the only MPEG-2 hardware capture card that I know of is the Dazzle DVCII. The everything uses the WinDVR software to capture MPEG-2.
I got this card about a month ago and have been really pleased so far. I have a P-4 1.4ghz 256mb rambus system and MPEG-2 captures at 720x480 have come out great. On one capture there was a problem with the low freq. audio, but I think that was more a result of my settings and not the card's fault. I paid 172 on pricewatch.com -
Thanks for the info. There are several hardware cards available, I was just hoping to have found another option for me...Can you by chance post some clips from your captures so we can see, with the specs on your capture? Thanks!
There is the Snazzi III, finally available in the US www.snazzishop.com - wish someone would get one & post a review
HDMI/DVI to PC hardware card
By ima2hd in forum DVB / IPTVReplies: 24Last Post: 13th Apr 2010, 11:20 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 14:39 -
mpeg files have this kind of image
By aruwin in forum Software PlayingReplies: 4Last Post: 6th Nov 2008, 11:06 -
Card with mpeg-2 hardware capturing for standard definition?
By Giantsloth in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 19:26 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
