Hi!
I'm not sure in which section I should post it, so i post here.
I want to downscale a WMV 1920x1080 to 960x540 which is exactly half size (each).
All properties of the video should remain the same, except the bitrate. Bitrate should also cut half from 8000 kbps to 4000 kbps.
So I tried "SUPER video converter". This program just want to convert to 960x544, because 540 isn't divisible by 16.
I tried it with 960x544, but SUPER "lost" some seconds of the video at the end.
I also tried the trial version of "Any Video Converter" - maxmium bitrate for WMV is 768 kbps here........
Is there a video converter out there which can do this job?
Thank you!
I tried it and it seems that this program could do it.
I never heard of this program. -
elliot,
Technically, you should be able to do 1/4 the bitrate since you're using 1/4 the resolution. (1/2 horizontal and 1/2 vertical...)Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
I don't understand why you would want to "destroy" such a wonderful source. OK I can maybe see going from 1080p to 720p if your TV is only 720p and/or file size is THAT important but to go less than 720p seems ... wrong.
With video we tend to strive for the best quality possible and here you are ruining an already quality clip.
How does VirtualDub sucessfully downscale HD to SD widescreen?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 7th Oct 2011, 20:08 -
How to downscale 1080 to 720?
By Catinaz in forum Video ConversionReplies: 3Last Post: 30th May 2010, 21:19 -
can i downscale 720p .wmv files?
By jake25uk in forum Video ConversionReplies: 2Last Post: 25th May 2010, 02:39 -
Import @ 1920x1080 or 960x540 (or why the Mac sucks for HD compared to PC)
By ArthurDaley in forum MacReplies: 14Last Post: 8th Aug 2009, 16:24 -
HD Web Video Test: FLV vs AVC vs WMV vs XVID, 960x540 @ 2 kbps
By Bubblevision in forum Video ConversionReplies: 9Last Post: 27th Mar 2008, 10:58
