I have been having some issues with my Samsung HT-X40 entertainment system. It was not reading quite a few commercial movie disks. I found a firmware upgrade for the system. I followed all steps in the documentation. System shows correct upgraded firmware number. Problem is now it will not recognize any disk put in it.
Any suggestions or ideas would be greatly appreciated.
While it is possible that you botched the firmware upgrade somehow, it does seem that the player was going bad anyway prior to this and your current problems may have nothing to do with the firmware. Try cleaning the lens (do a web search on how to do this) and see if that helps. If not, you could try to find the previous version of the firmware prior to your upgrade and try installing that. If that fails to fix the problem, it's time either for a repair or a replacement.
One of the problems with this kind of system is that you now have a single point of failure that will render the entire system worthless. When (not if but WHEN) the DVD player goes bad (and it will eventually), it will make your entire system useless because the player is also the receiver driving the speakers. At least it's not very expensive. -
On a side note, firmware updates most often do not fix disc reading issues. DVD technology has matured enough that disc reading issues have long since been resolved. Any reading issues you are likely to be having are either player or disc related.
Google is your Friend
Have a question about Magix MEP 17 and a Samsung SMF-X40 camcorder
By jgil7327 in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2011, 07:30 -
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 14:25 -
Samsung BD-P 1200 old firmware
By Deadite666 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Apr 2009, 15:29 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
Samsung 1080P7 firmware
By jsz in forum DVD & Blu-ray PlayersReplies: 6Last Post: 16th Jan 2008, 11:53
