Hi, I am using convertxtodvd and sometimes when I try to insert a background image the edges get cut off because it is to big. I tried using the Image resizer but the same thing happens. Any Ideas would be appreciated.
Just a guess, but it might be your TV overscan.
Does it exhibit the same behaviour when you playback on PC?
If so, you can resize the image with an image editor (like photoshop or ifranview, etc...). If it is overscan, put a dark border around the image, with the resulting final dimensions 720x480 for NTSC.
Replacing DVD menu made by ConvertXtoDVD
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 4th Oct 2010, 04:39 -
how to make the a4 background fit the whole paper ?
By freestyler9 in forum ComputerReplies: 3Last Post: 27th Feb 2010, 16:44 -
How create a custom Menu Backround when using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 14:49 -
animated menu w/ ConvertXtoDVD
By WhiteKenny in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2008, 15:13 -
How to edit menu templates in convertXtoDVD
By oodles in forum Authoring (DVD)Replies: 3Last Post: 16th Jun 2008, 11:16
