Ok, it was running normally up til yesterday. Then suddenly it says that I need to update...however, now that I update it, it won't stop bothering me about my databases being obsolete. After I click the update and it completes several times it ends up saying update not required but the program continues to say that they are obsolete...so what is wrong with it? I even ended up reformatting and wiping my HD to see if it will change anything in case if there was a virus, but it did nothing at all...I really need help to see what's wrong with this program.
I'm not familiar with that application. Have you contacted the app vendor directly or visited their support forum? Problems such as these are often known issues and the fix is noted in their forum.
Google is your Friend
Understanding Why Internet Service BandwidthUsage in Some areas is limited
By Moontrash in forum ComputerReplies: 6Last Post: 19th Feb 2011, 06:55 -
Getting Kaspersky warning with every page I open here
By lordhutt in forum ComputerReplies: 7Last Post: 25th Jan 2010, 14:11 -
Strange Problem after installing Kaspersky
By anirban in forum Newbie / General discussionsReplies: 0Last Post: 28th Jul 2008, 12:59 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 04:36 -
Are you satisfied with your current internet service provider?
By yoda313 in forum PollsReplies: 31Last Post: 26th Jun 2007, 02:13
