Hello,
I am new around here. I hope that I am posting this in the right place.
I live in the US and I am planning on buying a multi-region DVD player that can play NTSC and PAL movies, and that also does the 720p / 1080i upconversion.
I was actually looking into getting the Philips 5960. It seems to be the best and most affordable option. Does anybody have any other suggestions?
Also, can anyone recommend a place where to buy it?
Thanks a lot!
Results 1 to 10 of 10
OPPO 980( www.oppodigital.com ) or Philips 5982(Best Buy,Walmart,Amazon,etc).
Thanks for the quick reply!
I just went to amazon.com, and it seems that there are two versions of the Philips 5982. One for $69.99 and the other one for $78.99.
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=Phi...5982&x=11&y=21
The description of the cheaper one does not include any info about NTSC and PAL.
Are there really two versions of this player? Or is the expensive one the same one, but with the region code hack already entered?
I doubt there are two version of the same player.
Thanks again! -
The more expensive one is from another vendor,same player though.
The 5982 plays PAL and NTSC,it can also be made region-free:
https://www.videohelp.com/dvdhacks?dvdplayer=5982&hits=50&Search=Search
Tip:when playing PAL DVD's make sure to set output to NTSC not Auto. -
Thanks again!
By the way, just out of curiosity: what the difference between the Philips 5960 and the 5982? Is the 5960 no longer made? -
Yes the 5960 is discontinued,the 5982 outputs 1080p and has a USB 2.0 port to play files.Originally Posted by jtrinc
CircuitCity.com has the 5982 on sale and I just bought one.I was thinking of buying a OPPO 980 but this has the same features for alot less.
Thanks so much for the Circuit City hint!
I just bought one for only $52.99! AWESOME!!!
It even had free shipping, so it was a no brainer.
Thanks again! -
I got it today and it works great. I used the code included in the hack section and it plays my region 2 DVDs without any problems.
You mentioned that when playing PAL DVD's I should make sure to set output to NTSC not Auto. But it wasn't necesary to do anything. It just plays anything, whichs is awesome.
By the way, does this player play DTS audio tracks?
It is no big deal, but I didn't see anything about it anywhere. -
No onboard DTS decoder but you can use HDMI and have your receiver decode it.Originally Posted by jtrinc
BTW:I have been reading on the AVS forums and people say don't update the firmware unless it's absolutely necessary,too many people are bricking their players. -
All right. That's cool. Thanks again for your help and enjoy your DVD player!
Best PAL VCR player with 6-heads - multi region/system would be preferred
By jbloggs in forum DVD & Blu-ray RecordersReplies: 7Last Post: 16th Mar 2012, 16:20 -
Blu-Ray Player That can be Made Multi-Region, and Plays Divx USB?
By rdinsf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2012, 08:19 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 10:28 -
Does making a dvd player region free also allow PAL to display on NTSC?
By dizmack in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2010, 20:50 -
Good Multi Region XVID DVD Portable player with IN's n Out's?
By iC3MAN in forum Portable VideoReplies: 0Last Post: 28th Dec 2009, 15:57
