Hi,
I've just installed a new firewall (ZoneAlarm Pro) and I see DVDRebuilder tries to connect to a file that is hidden and you can't see unless you uncheck the "Hide protected operating system files recommended option"in Tools Menu Folder Options.
I denied the connection once and the encoding went OK. But prior to my zonealarm installation I suppose the program has always connected to rebuilder.child.exe.
Is that file part of the program or is it anything else?
Thank you in advance.
Results 1 to 1 of 1
question about batchfile "taskkil" command for audiorepeater.exe
By Ennio in forum AudioReplies: 0Last Post: 12th Apr 2012, 10:17 -
BD-Rebuilder "wavi.exe has stopped working"
By waynezo in forum Blu-ray RippingReplies: 7Last Post: 13th Mar 2011, 10:03 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20 -
NAME="mplayerc.exe" FILTER="GRABMI_FILTER_PRIVACY"
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2008, 15:40 -
question about how to remove this software, "wmfdist95.exe" WMA
By jimdagys in forum ComputerReplies: 2Last Post: 15th May 2007, 04:07
