I have a NVIDIA GeForce 8600 GT gaphics card.
I just got a second monitor, an Acer 20 inch widescreen.
I want to use both my monitors. I also want to connect my console to one of the monitors.
Is it possible to connect a console via a TV tuner and user one of the monitors as a monitor for my console and and when i wish?
Also do tv tuner cards support 5.1 audio, or does it depend on the card
Very few tuner cards support 5.1 input. I can't think of any off hand, although there are specialist audio cards that do. You will also get lower resolution in most cases using a tuner card, as you will be playing through a preview window. Unless your console supports VGA output or your monitor has it's own video in connections you will need a converter box or some type, and will still only get medium to low resolution.
Read my blog here.
sorry i dont think i was clear enough
I want to be able to connect the console thru the TV tuner card and play the console on the monitor thru the PC -
You were clear, I just don't believe you can do what you want in a satisfactory manner. TV tuner cards generally accept only analogue input at standard definition resolution, so you will be inputing at 720 x 576. On a 20 inch monitor that is less than one quarter the monitor's default resolution. You may be able to maximise the video, but that will just give you soft and fuzzy. You cannot plug a PS3 into a TV tuner card on a PC and get 1920 x 1080 input, for example.
Read my blog here.
Also the delay through the tuner/NVidia card will be substantial enough to affect game play.
If your console is an Xbox360, you can get VGA out cables cheap which will connect direct to the computer monitor at 1360x768.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
TV Tuner Box and HD Computer Monitor
By Sparky24 in forum DVB / IPTVReplies: 4Last Post: 22nd Oct 2010, 17:41 -
Analog Cable TV to HD LCD Monitor via TV tuner
By torrentkid in forum DVB / IPTVReplies: 0Last Post: 3rd Aug 2010, 06:19 -
Ultra Mon Dual-Monitor Question
By RKelly in forum ComputerReplies: 6Last Post: 11th Aug 2009, 11:02 -
TV Tuner Display on Secondary monitor?
By wakarusensei in forum DVB / IPTVReplies: 4Last Post: 6th Dec 2008, 14:51 -
a question about dual monitor video cards
By wingnut2003 in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 07:49
