Hey, I've been ripping movies recently, then all of a sudden my burning rate went all the way down to like 1 mb/s for some reason. Then when I went to play the DVD on my computer it just skipped non stop and made it unwatchable, so I put another DVD in and it did the same thing, meanwhile they all run fine on my TV DVD player. Anyone know what happened? I didn't download any new software so I don't think it's that. I've also checked to make sure that DMA is enabled.
Have you changed media brands recently, or just bought a new spindle of a brand you have been using successfully in the past ?
Have you tried using DVD Info Pro or Nero DVD/CD Speed to do a read test and speed test on the disc in question ?
Have you tried a disc that you know previous worked to see if this is a problem with the computer drive, and not the discs ?Read my blog here.
I have tried other DVDs in it and it's had the same problem. So I plugged in my HD DVD player for my XBox 360 and the DVDs play fine on that. So do you think I need a new DVD drive?
Could be a dirty/failing laser or possibly DMA has been disabled or the burner is now in PIO mode.
Google is your Friend
Help with burned DVD's skipping
By BDrums1971 in forum Newbie / General discussionsReplies: 20Last Post: 1st Sep 2013, 15:06 -
DVD skipping for Client - tried everything we can think of!
By trevmarps in forum Authoring (DVD)Replies: 15Last Post: 2nd Apr 2010, 15:46 -
Frame Skipping in Media Player Classic
By Sootmouth in forum Newbie / General discussionsReplies: 0Last Post: 7th Oct 2009, 19:00 -
WD TV USB Player 5.1 Audio Skipping
By njsges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jan 2009, 02:31 -
DVD keeps skipping!
By Variable in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 18:05
