Hi,
I'm trying to rip the new Bee Movie (Region 2), and it either has a nasty copy protection or the media I'm using is really scratched...
Every ripping software I used, failed with CRC errors (including newest DVDFab, AnyDVD etc).
But, I noticed that all is not lost. In the target folder, the ripping software has managed to copy large part of the VOBs before hitting the CRC error. Within these VOBs, I located the ones that contain the main movie (image included).
My question is: How to I create a new DVD from these VOBs (maintaining all audio and subtitles) ?
Have you tried using something like DVDDecrypter to just rip the ifo and bup files into the same destination folder?
If that doesn't work, try this:
http://www.digital-digest.com/articles/create_ifo_files_from_vobs_print.html-The Mang -
Thanks louv68 !
I followed the guide you mentioned, and it worked.
Then I had to change the color of the subtitles using DVDSubEdit following this guide:
http://download.videohelp.com/DVDSubEdit/Guides/ChangingColors/Guide.htm
Burned it, and it works great!
Regards,
Flash70 -
I'm glad you got it work, and figured out about the ugly green subtitles. I completely had forgotten about them.
-The Mang
How to cut VOB-file and create DVD from VOBs?
By john999UPR in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 10:07 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 16:26 -
How create menu to Vobs ??
By Seasonal in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2007, 14:10
