hello there
i am about to start a massive project to turn my 950 movie ( avi ) collection into a DVDs
i already managed the boxes and the empty dvds but i need some advice on couple of thing before i start
first
i was thinking about getting my self a barcode scanner just to identify the movie and get all the info about using my already built collection by using Extreme movie manager (http://www.binaryworks.it/extrememoviemanager/features.aspx)
but because my movies where downloaded using torrent and most of them are in avi or mkv format
i don't think that they have any sort of barcodes on them
so how can i add barcodes into my movies so i can get the full IFO file when i convert them into dvds using probably convertXtodvd v3 ( i need the ifo file to be their so the database building program can read the barcodes correctly )
second
whats the best way to creat some kind of a cool animated menu for my movies
i know their are some pro programs but i cant do that for 950 movie ? so are like menu templates that i can add to the dvd ?
or can any one suggest a better way
third
about the bar codes
after they are in the IFO file of the dvd
whats the best practical way to place them on the box ?
and are there any good barcode scanners that you wouldve recommend
thats the basic questions that i thought of for now
by the way this is for building my own personal database not for a store or something so no need for heavy dutty equipment and stuff
again this is for personal use
thanks in advanced
Edit : 1 more quistion
i was thinking that i need to get ( or rent ) a pc that have multiple dvd burners for this project
whats the most important things that i have to bare in mind while assembling the pc
i was thinking ( 2 g ram , 3 dvdburners x12 , and a cooling system )
You are in breach of the forum rules and are being issued with a formal warning. PLEASE read our rules before posting. We ask members not to discuss warez. Thanks
/ Moderator offline
Closed Thread
Results 1 to 16 of 16
Barcodes are printed on the DVD cases. If you want barcodes, buy the movies instead of downloading pirate versions. Even if you own a DVD, downloading a ripped version is illegal.
Read my blog here.
Where - in the movie ? On the disc ? As a subtitle ? There is no barcode on a DVD except for the physical barcode on the cover. Period.
Read my blog here.
Look for a barcode font. Google is your friend.
Ditto for barcode scanners.
However, how are you going to know that the barcode should be for some downloaded file ?
This whole project seems like a massive waste of time unless you are trying to create pirate DVDs that look half legitimate. Is this some type of eBay scam in the making ?Read my blog here.
There is software that will print barcodes.
There is free software that will catalog your collection, and even connect with the imdb (based on title name) to update the info contained. Irregardless of the legality of your collection;.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
not reallyOriginally Posted by guns1inger
this is my own dvd library so i want it to look nice
by the way i googled ditto barcode scanner and got nothing
where can i find that ?There is software that will print barcodes.
Try it without the dittoOriginally Posted by a7medo778Read my blog here.
If you want to see a product intended for your idea, check out Cyberguys.com.
Look for a carousel item that holds around 150 discs. It also has software and a barcode reader to do exactly as discussed.
The barcode is on the DVD case, not the DVD.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
wow really cool http://www.youtube.com/watch?v=si6kW3FWZWw&fmt=18
but i have about 950 movies
so i gotta buy 9 of these :P
well if any 1 have any other way for me to organize my collection be my guest
i currently have 3 1tb hard drives but as my collection grows its getting hard to keep the hard drives organized and i am scared that a fetal error hits 1 of them and all my affords well be gone with the wind
For that, you just download the original cover - available all over the Net...
With barcode and all...
For my Private Collection I edit the original covers: changing the faces. Just 4 fun.
Converting DVDs and Adding watermark
By streamingguy in forum Video ConversionReplies: 0Last Post: 21st Feb 2012, 08:01 -
Student needs help adding subtitles to Sopranos without converting
By Dains11 in forum SubtitleReplies: 12Last Post: 28th Aug 2009, 09:15 -
Help Adding Subtitles to an AVI while converting to an MPEG
By canas15 in forum ffmpegX general discussionReplies: 8Last Post: 26th Dec 2008, 23:28 -
Adding several movies to one title/menu
By dread in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 22:25 -
Adding Audio to DVD family movies - more complex issues than it looks?
By steve8443 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 12:51
