When exporting video out of Avid as AVI (uncompressed),
after a time a message appears: file size too large.
The file size at that moment is 1.9Gb and Avid does
not continue.
What can I do?
(My harddisk is NTFS formatted)
Thanks.
Some few(mostly older) programs can't make avis bigger than 2GB. See http://neuron2.net/LVG/filesize.html
Export the video in 1.8GB chunks, then stitch together again (File>Append) with Virtualdub (take care to select Direct Stream Copy under Video and Audio).
Export from Final Cut Pro to format editable on PC (eg. AVI) retaining HD
By adrien23 in forum MacReplies: 3Last Post: 31st Mar 2011, 20:45 -
convert .mp4 (from Sony EX1 camera) to .mxf (Avid Xpress Pro)???
By justwondering in forum MacReplies: 3Last Post: 14th Dec 2007, 22:27 -
Need to export from Avid Meridien Uncompressed Mov to something else Uncomp
By rgabel in forum MacReplies: 1Last Post: 2nd Oct 2007, 12:54 -
avid xpress pro on dell system
By macgvyer in forum EditingReplies: 2Last Post: 18th Sep 2007, 17:28 -
Avid xpress pro
By nirbhayn in forum EditingReplies: 2Last Post: 18th Sep 2007, 17:21
