hi alli have a PC2700U-25330-B1 smart modular 512MB DDR 333 PC2700 CL2.5 RAM chip in my PC, and i want to upgrade to 1G. i saw a RAM chip made from the same compainy. will this chip work with my pc/other ram chip? 512MB 184p PC2100 CL2.5 16c 32x8 DDR DIMM T001, Smart, ACA, SM5646485D8N6CLIBH. do the RAM chip have to be the same?
You have not provided any details in your profile about your motherboard etc.
Generally, the chips should work together but sometimes boards use proprietory memory and that is when the problems start.
If they do work together then your PC2700 memory will perform like PC2100 memory. -
crucial.com run their free memory test, it shows you what you can put in your computer.
PC2700 is sometimes backwards compatible. I'd go to www.oempcworld.com and verify were it mine. You'll get the correct RAM, and $3.95 shipping.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Question on configuring a RAM disk on WinXP 32-bit SP3
By PartingShot in forum ComputerReplies: 12Last Post: 4th Sep 2011, 13:13 -
Question on DDR2 RAM
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2011, 07:01 -
Window 7 Usable RAM question
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 10th Apr 2011, 07:19 -
Simple Hardware question's on Ram and its support.
By avengerevenge in forum ComputerReplies: 2Last Post: 8th Jul 2010, 08:35 -
Question about refreshing DDR RAM for video application.
By SingSing in forum Video ConversionReplies: 7Last Post: 13th Aug 2007, 10:41
