Hello,
I have a Sony - HDR-UX3E and filmed a AVCHD. If i playd it on PS3 everything works.
But I want to copy my films on HDD of Ps3. This doesnt work with PS3 software.
So I put the m2ts files (one file every scene) from AVCHD to my PC and try to join them with tsMuxeR_1.8.4b. and copied the joind file on ps3 HDD. everything works BUT some scenes picture and sound is asyncron.
what should i do to solve the problem?
Thanks for help!
Let loose the quality daemon!
If u had a solution to solve problem with smal quality loose and only with freeware. I am interessted in.
remove a logo without loosing quality
By mathmax in forum DVD RippingReplies: 13Last Post: 9th Jul 2010, 12:54 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 18:33 -
Need some help with new ps3 harddrive problem
By f-zer0 in forum ComputerReplies: 5Last Post: 22nd Jul 2008, 07:38 -
Erasing stuff completely on harddrive on ps3?
By f-zer0 in forum ComputerReplies: 6Last Post: 21st Jul 2008, 11:32 -
What to use to edit DVD (Video-TS) without loosing (much) quality.
By Scav2003 in forum MacReplies: 2Last Post: 2nd Nov 2007, 11:39
