Results 1 to 17 of 17
    Mar 2008
    Hong Kong
    hi, i am using classic ipod160G, converting vids with MPEG-Streamclip (1.2b2) from .mpg to ipod format. after converting and playing back ipod-vid on TV (via composite cables) or directly on the ipod, i have the following quality problems:
    * video show lines around edges, blurry and low quality
    * audio is not in sync with video...its faster
    I am however following the standard conversion setup in MPEG-Streamclip for ipod classic...so i am a bit at loss why this happens. can you pls tell me the the BEST setup
    (using PC/Vista)
    Please give us MORE information,
    More details about your source, video resolution, interlaced, etc? Identify the mpg settings with for example mediainfo.
    What settings are you using in mpeg streamclip? like video resolution, bitrate, deinterlacing.
    And I would try other converters and see if it make any difference like ripbot264, xvid4psp, etc.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I know some here don't agree with me, but I use Videora with custom high quality profiles, and get very good quality, no audio sync problems, and good encoding speeds.
    Many others recommend Handbrake, although I have never been able to get better than mediocre (and that is being kind) video quality from it.
    Read my blog here.
    Mar 2008
    Hong Kong
    here is the source info I get using media-info:
    General
    Complete name : C:\Users\Nils\Videos\Canon Home Video 2006-08\23. MAY08 Home.mpg
    Format : MPEG-PS
    File size : 1.35 GiB
    Duration : 30mn 20s
    Overal bit rate : 6349 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, Matrix : Standard
    Duration : 30mn 20s
    Bit rate mode : Constant
    Bit rate : 5652 Kbps
    Nominal bit rate : 9400 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4/3
    Frame rate : 25.000 fps
    Standard : PAL
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.907
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 30mn 18s
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Video delay : -80ms
    Menu
    Format : DVD-Video
    and now the output after conversion using stream-clip:
    eneral
    Complete name : C:\Users\Nils\Videos\Ipod vids\23. MAY08 Home.m4v
    Format : MPEG-4
    Codec ID : M4V
    File size : 355 MiB
    Duration : 30mn 20s
    Overal bit rate : 1636 Kbps
    Encoded date : UTC 2008-05-09 14:23:08
    Tagged date : UTC 2008-05-09 15:43:34
    Video
    Format : AVC
    Format profile : Baseline@L3.0
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Duration : 30mn 20s
    Bit rate mode : Variable
    Bit rate : 1504 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Frame rate mode : Constant
    Frame rate : 30.000 fps
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.163
    Stream size : 326 MiB
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 30mn 18s
    Bit rate : 129 Kbps
    Nominal bit rate : 128 Kbps
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Stream size : 28.0 MiB
    Language : English
    Encoded date : UTC 2008-05-09 14:23:09
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Your source is interlaced so you must deinterlace it. I'm not sure how to do it in mpeg streamclip though.
    I would also try handbrake or videora ipod converter as guns1inger says.
    Mar 2008
    Hong Kong
    i actually tried videora, same outcome...but probably because i only used "normal" conversion function which does not give all the advanced functions...guns1nger possible to deinterlace it? And will that solve all the problems?
    Apr 2004
    Miskatonic U
    Like I said, I use custom HQ profiles and have no problems with interlaced source.
    Read my blog here.
    Mar 2008
    Hong Kong
    can you pleaase give me an example of an HQ profile for classic ipod with interlaced source...thank you.
    Mar 2008
    Hong Kong
    Baldrik.guns1nger: I played around w videora, selected some HQ profiles but still the same outcome bad quality, lines around edges when moving pics and sound not in sync. I analysed the vids again with media info here is the result, I am at a loss why and need your help pls:
    General
    Complete name : C:\Users\Nils\Videos\Ipod vids (Videora)\14. NOV07 Julien.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 584 MiB
    Duration : 32mn 14s
    Overal bit rate : 2532 Kbps
    Movie name : 14. NOV07 Julien
    Encoded date : UTC 2008-06-13 01:16:56
    Tagged date : UTC 2008-06-13 01:16:56
    Writing application : Lavf51.19.0
    Video
    Format : MPEG-4 Visual
    Format profile : Simple@L3
    Format settings, BVOP : No
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default
    Codec ID : 20
    Duration : 32mn 14s
    Bit rate : 2400 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.312
    Stream size : 553 MiB
    Writing library : XviD 1.1.2 (UTC 2006-11-01)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 32mn 12s
    Bit rate : 128 Kbps
    Stream size : 29.5 MiB
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Try Xvid2PSP instead and see if that works better for you. I certainly don't see the issues you are seeing when I encode, but I cant see what you might be doing wrong, either. Can you post a few seconds of the source footage somewhere so I can do a test encode ?
    Read my blog here.
    Mar 2008
    Hong Kong
    in fact, when playing back the encoded vido on my laptop w quicktime, the quality is ok...the edges around moving objects are not as smooth as the original of course but its not as bad as playing back the same video on the ipdod and having it hooked up to a TV...quite strange that there is such big quality difference...my LCD TV is new so it cannnot be from the TV either...BUT I still hve the problem with sound that is not in sync...
    where can i post some footage?
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    How are you playing it on your TV ? What type of connection, from what device ?
    Read my blog here.
    Mar 2008
    Hong Kong
    am using the av composite cables to hook up my ipod with the tv directly...then just playing back directly from the ipod...
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Composite tables will automatically introduce some quality issues, such as crawl and noise. If you want better quality, you need to use component cables instead.
    Read my blog here.
  15. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    iPods don't have component output.
  16. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Apple sell component and composite cables for the iPod classic series and current widebody Nanos. They no longer sell s-video for these devices. http://www.apple.com/ipod/accessories/
    Read my blog here.
  17. Don't have an Ipod but the framerate change could be causing your audio issue.
